Brief Description: Verified fuel pressure meter / primer functional
The fuel line to the carby, which had been disconnected for fuel flow testing, was restored. Once the pump was switched on, a pressure indication began to be displaced, The pressure shown seemed low; this fuinction will be further monitored to see if the meter needs remarking, or what.
While in the pressurized state, the primer was checked. It indeed does spurt out a reasonable quantity of fuel, when the primer plunger is used.
