1) Unpacked cylinder. 2) Slipped pushrod boots and clips onto pushrod. 3) SLipped cylinder gasket onto cylinder. 4) Removed piston, and installed in on rod. 5) Worked piston back into cylinder. 6) Positioned cylinder over mounting bolts. 7) Finger tightened nuts in place, then torqued per limits table. 8) Positioned pushrod boots, and slipped clips over them. 9) Installed plug adapters and plugs
