Brief Description: Installed input and output connectors on Lightspee
1) Made service loop of excess sensor cable above Lightspeed units. Lightspeed says not to change cable lengths on sensors. Fixed in place with adel clamp. 2) Installed indicator wires and backshells on output connectors. 3) Tagged input and output cables as "top" or "bottom." 4) Installed input and output connectors on Lightspeed units.
Note: I have established the convention that the upper Lightspeed unit feeds the upper ignition coil and the upper plugs. The lower unit, etc.
Installed indicator wire and backshell on output connectors.
