1. temporarily bolted carby outlet maniford into position. Correct nuts are on order. 2. Positioned carby gasket on manifold, and slipped carby into place. 3. Mounted carby per Continental IPB. 4. Cleaned, degreased, and stripped the carby air box. 5. Coated with rust converter, allowed to dry, then painted with high temp black paint. 6. Installed Brackett air filter assembl;y BA-4106 on front of air box.
Note: This filter is STC'd on Cessna 150s and aircraft with larger engines, so it should have no trouble providing the required air.
7. Installed gasket between carby and airbox. 8. Bolted aft of air box to carby. The front awaits hardware on order.
