Brief Description: Added seals to side and rear baffles
1. Measured needed length of seal. 2. Cut seal to lengthj. 3. Set up rivet pattern on baffles with 80 mm spacing. 4. Drilled #30 holes for rivets. 5. Clecoed in place, using a #6 washer as backing. 6. Riveted with Avex rivets. 7. Replaced in aircraft.
