Brief Description: Did initial fit of lower engine cowling
1. Fit bottom cowl into position, centered on prop flange. 2. Aluminum forward of fuselage interferes with cowling, and must be removed. 3. Cut aluminum back to 2" beyond fireway as initial estimate - may require more. A. Marked line 2" forward of firewall. B. Cut along line with rotary cutter.
