Brief Description: Installed remaining parts on center console
I made the decision to install not just the fuel selector valve, but the fuel indicators, the trim switches, and the trim indicators on the center console (6K2-2). It's drowded, but I still believe this is the most logical place for this stuff.
1. Installed remaining items on 6K2-2. 2. Tinned leads on trim indicators and switches. 3. Begain splicing leads between console and rest of aircraft.
Note: Console has a service loop so it can be removed for maintenance or wiring corrections.
4. Installed cable ties on resulting harness.
Note 1: The fuel lines, and line from the fuel sensors must still be installed. Note 2: The trim switches and indicators do not have goot color coding to indicate up-down. I would be very surprised if some of these leads do not require swapping.
