GLENN C'S WEB SITE
S-20 Raven
Cable Rub Blocks
Gathered parts for left and right cable rub blocks. Using bolts aligned nut plates, drilled #40 and riveted nut plates to cover plate. Using large drill bit made reliefs in the rub blocks for the #40 rivet heads so top plates would lay flat.
Checking nut plate orientation
Nut plates riveted and reliefs completed
Assembly loosely attached
S-20 Raven Home
824
Covering
60
200
228
155
