Brief Description: Compression Tubes and Bell Crank Braces
Deburred all holes in compression tubes and doublers. Slid the compression tube doublers inside the bell crank compression tubes, cleco'd bell crank braces into position on the long wing channels. Transfer drilled the two #11 holes in the compression doublers for the aileron bell crank mounts. Drilled and cleco braces to the compression tubes
