Brief Description: Flap Hinge Nut Plates and Drag Tubes
Located flap hing holes on rear spars and drilled to #11. Deburred, installed bolt through spar and into nut plate to hold in place. Drilled #40 holes and riveted nut plates to spars. Retrieved drag and compression tubes, deburred holes and temp bolted them to the spars on the saw horses.
