RVGator
Date:  1-28-2012
Number of Hours:  2.50
Brief Description:  1. Removed uncured epoxy
Well over a week ago I put on the coat of clear epoxy on the skirt, today I go to sand it and it gets all gummy. It obviously was mixed up wrong and did not cure. I quickly learned the only fix is to take the bad stuff off. So I spent a couple of hours with some acetone and rages taking off the uncured stuff. Then sanded and cleaned and put on another coat. After that coat set up some I rolled on a second coat.
Note: The next day the epoxy was still soft, I brought the cowl up and set it in from of the fireplace and it all cued up hard as nails. I just need more heat in the garage, why did I do this last summer!
Temps at the lower side where 105  and 95 at the top.  This got the room up to new 80 degrees
