I am only doing fiberglass work, which only takes a couple hours then it has to set up 24 hours. I could do other stuff but it is the weekend and I like to spend time with Anita so a short day.
I have to lay up the last layer on the seam at the rear, I also need to fill the gap maid trimming things to clear the track. I pushed in some clay around the edges to support the cloth. Then I laid two layers on top of the seam and two over the track area and left it to set up. The only picture was taken the next morning after it set up.
