I sanded down the filler from yesterday on the FAB. I read over the alternate air door instructions. I am trying to decide if I should use the metal ring or use the fiberglass version I started the other day. Some have had the rivets pull thru the glass from vibrations.
I was finally getting warm out so I headed back home to prime all the baffle parts.
I made a glass ring using the metal one as a form the other day
