After making the paper template I was happy with my bracket design so I made one out of some scrap aluminum. I then made the two tubes for the AOA and Pitot, I also made some keepers to hold the tubes together. To hold the tubes under the console I fabricated a tab that will fasten to the cross brace of the console frame. The tab has two grommets to hold the tubes in place.
My Avery delivery came in so I cut and drilled the nylon block which will hold the upper part of the tubes. I still need to drill the hole in the F802 bulkhead and paint the bracket but I am happy with hour it all came out.
Upper bracket to hold tubes
Tab to hold lines under the console
You can see the lines run under console, outboard of the idler arm and then up to the instrument area.
