Brief Description: New connection between ANL and Relay
While the floor panel dried I tackled making a new copper strip to connect the ANL to the start relay. The first one was a little short and would pull too much when everything was tight. Once I had the fit I wanted, I added some shrink wrap to protect the open area of the bar from accidental grounding.
You can see the yellow cable does not go up though the firewall. I removed it, decided to scrap the grommet shield method for the SafeAir1 firewall pass though system. They are pricey but make running wires through the firewall easier. I will have two, one for the power wires and one for the sensor wires. I will cut those holes later this month when I get back from work.
