I borrowed some 14 AWG wire while mine is on order this allowed me to pull the wires for the left wing. I then used solder tubes to connect the wires. The solder tubes make a nice air tight connection, I regular butt splice would have more potential for corrosion. I space then splices out so things should run into the conduit easily. The idea is as the wing is lid into place the wires will pull though the conduit.
I then pulled the antenna cable for the VOR antenna that will be in the wing. I had planned to use the holes along the aft side of the spar for this I even installed all the bushing in the building of the wings. Well the roll servo for the auto pilot gets in the way. Rather than try and find a way to run the coax around the servo I had room in the conduit to run it with the other wires. This is high end coax so it should not cause any interference and if it does I will pull it out, the VOR is becoming an obsolete navaid with the modern GPS.
