I then turned my attention to al the nut plates that go into the wing. The first step is to remove the burrs then drill the holes for the nut plates. Happily I have a nut plate jig and used this to drill the multitude of holes for nut plate rivets. I stopped after getting all the upper wing rivet holes drilled. When I can find an extra hand I will flip the wing over and drill the lower wing.
