Busy day today, I started by rolling on a layer of plain resin to begin the finish on the windscreen fairing. The roller left bubbles but those will sand out and filled with what I hope will be the final layer. I added a second layer after the first was set up some. I will sand then squeegee on a final layer before priming. I need to get this primed before the move to the airport, I can do primer on the cowl since I can bring it home but I can’t paint in the hanger so the windscreen needs to be done here.
