RVGator
Date:  2-28-2012
Number of Hours:  2.75
Brief Description:  Primed inside of skirt
I managed to sand down the spot the air hose hit the wet paint yesterday and then filled a few spots where I had pin holes. I sprayed another coat of the epoxy primer and followed that with the K36 filler primer. I am happy to report that I managed this without bumping the wet paint! I still can’t get the primer to spray like paint, it does not seem to flow smoothly but it gets covered. I have a kind of a micro orange peel look. For the inside of the skirt I plan to leave it as is, I have plans for some fabric panels to fill the areas between the supports of the canopy frame. Time to get this sucker glued on to the canopy.
Left upper edge plain, the Sika glue will hole better to the fiberlass.
Fill a few pinhole left and sand
