Brief Description: Hooked up fuel boost pump wires
Well let’s see if I can catch up on log entries. I returned from a 12 day trip and still recovering from jet lag but did some work today. It was short since I picked up another trip for some overtime flying.
I keep thinking of things to do before I get the plane up on the gear. I had to lace tie some more wires in the electronics bay otherwise known as the lower baggage area. The next thing up was to install the control cable for the heat valve. I drilled the hole in the vent panel I made but decided not to terminate the cable at the valve until I have the engine control cables installed. I want to make sure I will not have any interference issues with the heat cable and the engine controls. The last thing I did was to connect the power and ground for the boost pump, I also started to lace tie those wires before I called it a day.
AFP warranty is voided if you mess with the wires that come with the unit, don't know why
