I was going to wait on the front power outlet but since I had the baggage wall out I cut the hole and installed the power outlet. I used some sticky anchors to hold the power and ground wires from the outlet the power outlets front and rear will allow use of heated vests for those higher altitude trips. Most important for the rear seat since it gets less of the heat from the heat vent and it can be a little drafty around the back seat, or so I hear. I am trying to mitigate the draft and cold that I have heard about as much as possible. I had to knock off since I need to get ready for my trip.
