Brians RV-10 Construction
Date:  8-20-2006
Number of Hours:  4.00
Brief Description:  Throttle & Mixture cables
Well it's been a while since my last post. I came back from Airventure and decided to take a break from building and spend time on family stuff.Today I started back on the project and decided to tackle some of the firewall forward stuff. The AFP servo cannot be mounted with the Van's supplied cable bracket; you have to use theirs. I figured out that using the same trim cable anchor brackets used in section eleven would give a nice clean installation. Here you can see how I assembled it.
Mixture control side
Trim cable anchor bracket used in section 11-8
Right side for throttle cable
