Purchased an Ameri-King ELT from Aircraft Spruce and a strobe mount from Van's. Had to modify it slightly to fit the right side of the aircraft as the plate is taller on one side than the other and designed to fit on the pilot side. I basically flipped it upside down and notched it to fit the stringers.Installed the antenna under the empennage fairing.
