Brief Description: Front floorpans and soundproofing
Cleaned, primed, soundproofed, and installed the front floorpans. Used a closed cell soundproofing foam from Aircraft Spruce. Same material Tim Olson used on his project. I purchased the 3/4 thick material and will use it on the fron and rear pans.
