I've regressed back to section eleven! Well, really it's just that I want to wrap up a whole section of the aircraft. After getting the HS, VS, elevator, and rudder fairings done I decided to put the whole assembly together (as in flying condition) and at least feel good knowing I have that portion of the aircraft completed. My goal is to wrap it all up by Dec. 31st.Here you can see all of the flying surfaces are in place with exception of the rudder. I'll wrap that up next week. The fairing is clecoed in place for fitting. It needs to be removed once more for counter sinking the screw holes and trimming along the scribe lines.
