Brians RV-10 Construction
RV-10
Rudder Pedal Assembly
Installed the rudder pedal assembly into the fuselage and began running the brake lines. One of the AN3-22 bolts came up short has I had to install an extra washer so the nut would clear the mount. Ordered a longer bolt from Aircraft Spruce.
RV-10 Home
1223
A/C Hardware & Supplies
334
Flight
450
Hardware
Insturment Panel
Paperwork
Systems
Training
