No pictures of the pre-laminate were taken before spraying. The only two pictures available show the pre-laminate adhered with epoxy. No white areas to the front of the pre-laminate show when the Sikaflex is used. A smooth, pinhole free surface results with no filling or sanding…way to go…though, some filling is required in the corner of the screen and along the forward edge of the pre-laminate as it goes down below the corner. A better template might have resolved this.
