Over three work sessions I connected the parking brake switch cable forward end to the the previously mounted parking brake valve. This valve is located on the foremost bulkhead under the bow deck. The cable was run back along the top inside edge of the pilot-side FRP hull and secured in place with tie wraps and tie mounts that were previously riveted to the the top inside edge of the hull (Chapter 47). Then I bent a steel bone tang to 90 degrees and drilled out one of its holea to 3/8" to allow this support to be bolted to the side of the hull. A notch was cut into the lower edge of the bow deck control panel face to accomodate the pull switch. Voila.
