I finished off the right slider rail and bolted them both in place. A little tricky getting the washer and nut under and around the lip of the canopy rail but after struggling with the first one the rest were pretty easy. The problem was that I didn't have a 11/32" open end wrench which was the only thing I could get in to tighten the nuts. I llooked like a 9mm would fit but 10 was the smallest I had. So off to the hardware store. I did it at Half time of the packer game. Did a little more adjusting of the frame then said Good Enough! Drilled the top rail in two places once I got it just right. Drilled them #40 for now. Alos drilled the holes for the rear all thread bolt which holds the rail in place at the forward angle. This can be adjusted later if needed.
Two #40 holes forward and aft right in the center.
