Drilled the Canopy Release handle 5/8" hole with a Unibit as described in the manual. Elongated it to fit the enlarged area closer to the frame. This will also give me a little movement fore and aft for alignment. It will be covered by the center flashing strip. Also cut the Canopy along the bottom side frame. This is not the final cut. It will end up being cut above the frame.
Hole for the Canopy latch.
The frame clamped in the Canopy just after trimming the sides.
Once the Windscreen is cut free the Center frame will contour to the Canopy.
