Well, I did it. The first cuts on the canopy are to cut the flange off all the way around. Not a problem. After cutting the Canopy I set the frame inside to see how it fit then I marked the hole position in the front and rear right on the Center line. Oh, I forgot to mention that I measured the center line of the Canopy from front to rear. I've changed my mind on where the Latch hole will be. After ready the RV7 yahoo mail, there was a discussion about someone that had problems with there canopy and wished they had moved the frame forward so that the Ducktail would have not been a factor. I went back out and moved the Frame around and it looks like about 5/8" forward will do it. I heard the Ducktail can be a problem when fitting the skirts. I am going to wait on a response from an email I sent out to the group. GOOD NIGHT!
The dust gets a little much a times. But not to bad.
Layed the frame inside the canopy.
Marked the Canopy latch point so the hole can be drilled.
