I've decided to route the cables straight through from each unit without connectors at the wing root. I figure if I need to pull the wings off someday, I can always add connectors. Didn't like Van's placement of wire holes so I punched some smaller holes back a little under the seats. This will keep alot of the wiring away from the stick weldment area.
Wire runs out to the wing roots.
Heat shrink over cable exiting the aft fuselage.
This is how it exits the inside of the Aft fuselage from the conduit.
