After spending over an hour trying to figure out how to use the tool for crimping the AMP connectors, I finally got it. I diecided that I would run the sheilded cables all the way back to the firewall ground block. I saw this on Dan C's web site so I went ahead and spliced in a short wire for when I make those runs.
You can see the white wire for the sheilded ground.
