I changed how I was going to make my wire runs from rear of the center spars to the forward side. I had originally gone straight through and then ran through the grommets along the Fuel and brake lines. I didn't like how that was going so I put some Conduit between the spars and ran wires throught it. I will see if my TC approves of this.
Conduit between Wing spars.
Made up a post to mount an adel clamp which holds all the wires to the Strobe power.
Here they are running into the conduit that runs under the baggage floor.
