Brief Description: Manifold pressure sensor and Main Buss Diode
Added the reversing DIode per the AeroElectir Z-12 drawing. This will allow me to run the Aux Alternator in case of a main failure. The Diode prevents power flow back to the the Main Buss while allowing flow to the E-Buss. Installed the Manifold pressure sensor right behind the firewall (Right). The Manifold sensor fitting at the firewall has a reducer with a 1/8" to 3/32" nipple that I had to bring up to a "T" fitting where one end goes into the Sensor at 1/4" and out to the Electronic Plasma II box at 1/8". I have pictures on a previous day (3/14/2006) which shows in detail the parts list for this colostomy.
Manifold Pressure Sensor to fitting out the Firewall.
Engine side of Manifod fitting.
The Reversing Diode is mounted face down so I can get at it when the panel is dropped.
