Mounted the E-Buss and Main buss to the drop down panel. You can also see the Wig-Wag flasher on the right sub-panel. I am also adding nut plates under all the lips of the sub panels and pretty much any where a bundle uf wires might run that way I can just screw in a Adel clamp and its a done deal.
