Brief Description: Lightspeed Plasma II mount bracket
Got started a little late tonight (Long day at work) but came up with this design and location for the Lightspeed Plasma II ignition. I originaly had this mounted to the Sub panel but after review of the coax cable path and having to route it along the panel then forward through the firewall, this design will make it closer to the firewall and make a straight shot to the firewall. When configuring things from the top of the fuselage you need to remember that you will not have access to the electronics so your need to look at it from the bottom. I was going to mount it face up but mounting it this way (Face down) will give me much better access to the cables.
I cut out notches for the Input/Output cables and the Manifold pressure line.
Here is the other side where the ignition wire terminate
From in side the cabin above the Pilots feet. You can see the brake cables on the left.
