Before I get to the panel paining I needed to finish up the Parking brake cable. I snaked it through the Panel through the sub panel then through the left top rib and clamped it for support at the rib near the firewall. I made a little "L" bracket from some .025 aluminum then drilled holes for mounting to the rib.
The adel clamp holds it well.
Snakes through the bays.
I also made a bracket for mounting the WIG-Wag flasher.
