Mounted the LSE Plasma II ignition on the left forward side of the sub panel. The coil wires will come out of the outboard side and the Crank sensor input connector will be on the inboard side. I installed nut plates (4) on the unit itself then bolted it through the sub panel. This should make it easier to remove if need be.
Shouldn't have any problems with the ignition wires and
Also drilled a hole in the sub panel and installed a rubber grommet for the EMS Monitor EGT/CHT wires.
