Messed around with the ignition wires that run from the Lightspeed box to the coils on the engine. Punched through the firewall and installed a bushing in the hole then ran the coax lines through it. Nothing to terminate yet since I need to move the coil on the engine and the baffling needs to go in first because they run through it. I secured the mag wires to the engine mount with adel clamps. The right wires are just long enough with no slack. Not sure if I like this.
Electronic ignition box on the cold side of the firewall
