Tonight there was a weather warning for our County. Heavy winds, Hail and possible tornado's. I figured I wouldn't work on the plane because of this.... RIGHT! I stood outside and took pictures of the huge full rainbow. It was a little dark out but got this shot. You can sorta see it. Since the storm was overhead I thought, why not, lets jump into a pile of metal:) I worked on the heat muff. The muff goes together with two long bolts that run through the circular tube then ties both caps together on the ends. Th muff slides over it then gets secured with stainless steel clamps. I ran in one of the vent scat tubes to the firewall. The other inlet scat tube goes up to the Baffle when installed.
Rainbow starting at the bottom right.
Scat tube on the left goes to the firewall for heat in the cabin.
Worked on the fuel primer line. Secured to oil sump pan bolts.
