I finished up the alternator wire at the AMP shunt. I then moved on to Left RPM, Oil Temp, Oil Pressure and Fuel pressure wires that run from the Dynon EMS-D10 to the sending units.
Alternator termination at the Shunt
I'm using the P-Lead off the Mag for RPM which requires a 1ohm resistor in line.
