I did a few more things tonight before shutting down. I installed the Mixture and Throttle cables so I can accurately measure the other ends for the Quadrant brackets. I also picket up these Jam nuts for the Rod end bearings. They do not come with the Spruce attachment kits. The cables need to be taken apart to get them through the firewall and brackets. The rubber and plastic boots slide off then they fit through the holes.
The mixture bearing has two three small bushing/washers in the build up.
The Throttle bearing gets a 35/64" bushing that you need to cut from stock. Not sure why so long.
They both are very smooth through the entire throw.
