Before the rigging I installed both Ailerons and Flaps so that I could check the trail and install the Flap pushrods. The pushrods will need alot of work taking on/off a number of times to make sure the hole in the bottom is not too big. The ailerons are much easier to install without the flaps on.
Hung the Aileron and installed the bolts.
Installed the Aileron pushrod at the control stick.
