I assembled the Aileron Pushrods and inserted the Bellcrank Jig. After setting the pushrod lengths I found that the pushrod bearing on the W-716 Stick to Aileron pushrod will be too short. There will not be enough threads in the tube. I am going to order some MD3616M to replace the ones on the W-716, which have a longer shank. The bearing end is a little larger but wont be a problem since I can remove washers if needed.
