Time to installed the Flap weldment and cut the hole for the pushrod. From looking at verious techniques from others, the first side will be larger than the second (Learning process). You need to just take your time take a little off at a time and fit and refit the pushrod.
Installed the Flap weldment again
Here is the location you start the hole for the pushrod.
