Brief Description: Completion of Section 13 Wing Spar Assemblies
Cleco'ed the W-1206V Attach Angles to the W-1206-L & -R Spar Assemblies as shown in Figure 1 reference page.
Oriented all of the attach angles so the short flange contacts the web of the spar and points inboard.
Cleco'ed the W-1206T Attach Angle to the outboard end of the W-1206-L & -R Spar Assemblies per same figure.
Riveted the W-1206T Attach Angle to the W-1206-R Spar Assembly and riveted the W-1206K Attach Angle already attached to the W-1206-R Spar Stub Doubler as shown in figure 2 using LP4-3 Rivets.
Riveted all of the W-1206V Attach Angles to the W-1206-L & -R Spar Assemblies per Figure 3 using LP4-3 rivets.
Following Figure 3 Riveted the remaining holes marked with a symbol using LP4-3's and LP4-4's per the Figure symbols.
