Removed all parts and greased the WD-1211-L & -R Brake Pedal Torque Tubes with Aeroshell 33 Grease then slide them into the WD-01206-1 Rudder Pedals. Secured the WD-1209 Brake Pedals and F-1290 Pedal Blocks to the WD-1211 Brake Pedal Torque Tubes using AN4-15A bolts and 1 each NAS1149F0463P Washers and AN365-428 Nuts per figure 3 page 28iS/U-03. Attached the master cylinders to the WD-01206-1 Rudder Pedals and WD-1211-L & -R Brake Pedal Torque Tubes using 1 each MS20392-2C19 Pin, NAS1149F0363P Washer, and MS24665-132 Cotter Pin on the shaft side of the cylinder and 1 each AN3-7 bolt, NAS1149F0363P Washer, AN310 Crown Nut, and MS24665-132 cotter pin on the body side of the master cylinder per figure 3 same page.
