Straightened 2 1/2in of ATO-035x3/8 tubing to make the F-12127J by flaring one end of the tube, placing both sets of nuts and sleeves per figure 1 page 27iS-10 and flaring the second end. Attached the F-12127J to the left side of the fuel valve and the Fuel Drain Assembly per figure 2 same page. Attached the Fuel Drain Assembly to the F-12109A with 2 AN525-832R10.
Straightened 7 3/8in of ATO-035x3/8 to fabricate the F-12127H by making two 90 degree bends as shown in figure 1 page 27iS-11. Then placed the sleeves and nuts over onto the tube and flared both ends.
Straightened 7 1/8in of ATO-035x3/8 to fabricate the F-12127G made the 43 and 137 degree bends per figure 3 same page added sleeves and nuts and flaring both ends.
Straightened 11 11/16in of ATO-035x3/8 to fabricate the F-12127E made the 70 and 110 degree bends per figure 1 page 27iS-12 added sleeves and nuts and flaring both ends.
Straightened 12 23/32in of ATO-035x3/8 to fabricate the F-12127F made the 174 and 6 degree bends per figure 3 page 27iS-13 added sleeves and nuts and flaring both ends.
