Riveted the C-01213A and C-01213B in place using CR3212-4-08 rivets per call out of figure 2 page 24iS/U-02. Riveted along the flanges of the Rollbar Assembly starting with the center and moving outboard using CS4-4 and LP4-3 rivets per figure 2 same page.
Cleco'ed the C-01205A Canopy Block Drill Template onto the bottom of the Roll Bar Assembly per figure 1 page 24iS/U-03. Match-Drilled #30 the indicated hole of the C-01205A into the Roll Bar Assembly per same figure and removed and deburred. Machine countersunk the three holes called out in figure 1 and riveted with three CS4-4 Rivets. Tap'ed #8-32 the three holes in the Roll Bar Assembly for the screws shown in figure 2 same page. Installed the dome head rivet (LP4-3) shown in figure 2 same page. Machine countersunk the C-01205-2 for the heads of the AN509-8R14 and AN509-8R10 screws as shown in figure 2 same page then installed the C-01205B to the Roll Bar Assembly using 2 AN509-8R14 and 1 AN509-8R10 screws.
Separated the F-1232B into -L and -R parts. Removed areas marked in figure 4 same page from the F-01254-L-1 & -R-1. Separated the F-01254A into -L & -R parts per figure 5 same page. Filed and deburred all. Drilled #17, deburred, and dimpled both holes in the F-01254-L-1 & -R-1 for a #8 screw head. Dimpled the three #30 holes on the fwd end for flush blind rivets. Broke the top edges of the F-01254A-L & -R per figure 6 same page. Cleco'ed then riveted the F-01254A-R onto the F-01254-R-1 as shown in figure 6 and mirrored for the left side.
